ROGER'S WEB SITE
Date:  5-18-2008
Number of Hours:  5.00
Brief Description:  Prepped and riveted the rear bulkhead; rejoined th
I got up early (0600) and started working while it was still relatively cool outside. I squeezed and bucked the necessary rivets to attach the rear bulkhead together, and rivet the assembly to the tail section. It was over 90F by the time I stopped at 0815. The tail section is now ready to be joined permanently to the fuselage. Came back later in the day and rejoined the tail section to the fuselage and riveted the skins on both sides. Started riveting the bottom bulkhead to the bottom fuselage ribs. Again worked in heat a few minutes at a time.
Rear bulkhead riveted to tail
Rivets set in left side skin
... and in right side also.
